Documentation for Users  2.0.4
Perception Toolbox for Virtual Reality (PTVR) Manual
Create a tangent screen
The tangent screen is a special object of PTVR (that does not exist in Unity). You will a priori use it much more often than the flat screen object.
PTVR definition of the Tangent Screen Object
The 3 defining characteristics of a PTVR tangent screen are the following:
a/ The position of a tangent screen is defined by the position of its center (called the Screen Origin - SO).
(This is identical to the flat screen).
b/ A tangent screen is tangent to the sphere centered on the origin of the current coordinate system and having a diameter equal to the distance between this origin and SO.
(This is not a defining characteristic of the flat screen).
c/ The orientation of a tangent screen is constrained so that its local horizontal axis is parallel to the horizontal plane (i.e. XZ plane) of the GLOBAL coordinate system.
Placing a tangent screen in cartesian coordinates
The following bit of code creates a tangent screen and places it in my_scene with a position defined by the triplet of cartesian coordinates (0,0,1) (as illustrated in figure 1).
my_scene = PTVR.Stimuli.Scenes.VisualScene ()
my_tangent_screen = PTVR.Stimuli.Objects.TangentScreen ( position_in_current_CS = np.array([0, 0, 1]) )
# position : x=0, y=0, z=1 in the the GLOBAL system
my_scene.place (my_tangent_screen, my_world)
Figure 1: Grey Tangent screen at one meter from the Origin on the Z axis. The screen center is called SO (Screen Origin).
Figure 2: Animation (horizontal rotation about Y) of figure 1 to allow you to build a better mental representation of the 3D structure of the figure (as if you were able to look at it from different angles)..
Once the Tangent screen has been created, changing its parameter 'position_in_current_CS' has no effect (this is the same as for any object). It is therefore necessary to apply methods of the tangent screen object. For instance, it is possible to change the cartesian coordinates with the function set_cartesian_coordinates(). Using this function, the following bit of code creates a tangent screen and places it at the same position as the one shown in Figure 1.
my_tangent_screen = PTVR.Stimuli.Objects.TangentScreen ()
my_tangent_screen.set_cartesian_coordinates (x = 0, y = 0, z = 1)
Placing a tangent screen with perimetric coordinates
The following bit of code creates a tangent screen and places it in my_scene with perimetric coordinates.
(as illustrated in figure 3).
my_tangent_screen = PTVR.Stimuli.Objects.TangentScreen () # default position (0,0,0) is not shown.
my_tangent_screen.set_perimetric_coordinates (
eccentricity= 30,
halfMeridian = 90,
radialDistance = 1)
Figure 3: Grey Tangent screen whose position is defined with perimetric coordinates (eccentricity=30, half-meridian = 90, radial distance = 1). The screen center is called SO (Screen Origin).
Figure 4: Animation (horizontal rotation, i.e. about Y) of figure 3 to allow you to build a better mental representation of the 3D structure of the figure (as if you were able to look at it from different angles)..
When to use it ?
The PTVR tangent screen is often used to place stimuli on it (see Placing Objects On Tangent Screens).
Remember
The orientation of a PTVR tangent screen is constrained by its position (see Orientation of a Tangent Screen).
Demos
Path of Demos:
...\PTVR_Researchers\Python_Scripts\Demos\Screens\
Python file
Description
2.0.0_create_one_tangent_screen.py.
Create a tangent screen :0)
